Two way radio antenna KW T800?
redfarm
Posted 6/29/2024 08:55 (#10791796)
Subject: Two way radio antenna KW T800?
N. IL
Need to install a two-way FM radio antenna on a Kenworth T800 daycab semi. Looks like headliner is very difficult to remove and no other access to the roof. Where should we install it? Generally they are best mounted on a wide flat surface.
I mounted the 2 way radio under the CB mount in the overhead console.
