Will JD 560 R & M round baler PTO shaft shield fit 569? Part# AFH216878
Mr Green Jeans
Posted 6/29/2024 10:54 (#10791926)
Subject: Will JD 560 R & M round baler PTO shaft shield fit 569? Part# AFH216878
MT
The R & M driveline covers are shaped different on top and are supposed to help reduce hay buildup there. The covers are made of steel and are hinged at the rear. Located above the PTO shaft on the baler in front.
The 569 cover is flat on top. Will they readily interchange with the 569? Part # AFH216878
https://shop.deere.com/us/jdb2cstorefront/us/product/AFH216878%3A-PT...
Edited by Mr Green Jeans 6/29/2024 12:42
