ATTN Hagie 2006 and older
mike in sw mn
Posted 7/4/2024 11:34 (#10798113)
Subject: ATTN Hagie 2006 and older
Walnut Grove MN USA
I had the servo motor on the pump control quit working on my 2005 STS10. It is for the most part unavailable. John Deere doesn’t have it and basically says good luck getting one. It is a Raven valve and Raven has them but for some reason it takes them a month to ship it out. I found a pwm valve to replace it. I run my sprayer with a Trimble system that totally bypasses the Raven system so it will work. If you are running the Raven system IDK.
