Search Forums | Classifieds (20) | Skins | Language
Case 1070 Hyd vs. JD 946 Moco
in-too-deep
Posted 7/4/2024 14:39 (#10798279)
Subject: Case 1070 Hyd vs. JD 946 Moco
56676
Hello all,
My white 1070 won't lift a JD 946. It tries, but wont pick it up. If I loosen the floatation springs a bunch, it gets better. It swings fine.
All the remotes are putting out 1800 psi at idle and 1850 to 1900 psi at 2000 rpm according to a new 5000 psi gauge. The 946 op manual says it requires 2250 psi.
I'm going to check the empty side of the slave cylinder on the right for oil, but what else could I check? Is 1800 psi just not enough? Weak pump? Weak relief valve?
Thank you.
