Bethune, SK | Hi. I run a 2096 Case paired with a MacDon A30D haybine to cut about 800 acres of hay each summer. I always find rocks and treasures in the fields that I wouldn`t mind picking up before I forget about them. Would like to find a way to mount a rock box to either haybine or the tractor. If I mounted to the haybine would have to go on the back frame of it as to not mess with the header float. But not alot of spots there. The only thing I could come up with is to make something overtop of the swath forming shield.
The other option would be to go on the RH side of the tractor. We have weights on the front that I don`t want to get rid of. 70 lbs of rocks on one side of the frame shouldn`t much matter, have a toolbox on the other side anyways.
Has anyone ever mounted a rock box to a haybine?
Or to the side of their tractor?
Send in pics.
Thanks .
(IMG_1986 (full).JPG)
Attachments ---------------- IMG_1986 (full).JPG (264KB - 63 downloads)
